Ok, also noticed after install I can no longer hear some of my local radio stations clearly. I checked the antenna seems to be pushed in all the way into the D3. Any suggestions?
Reception on a Subie
Hook the D3's antenna turn on lead to the car's antenna amplifier wire.
Don't know what kind of subaru you've got, but this might help.
i just put one on my subie and dont have any problems yet hope u figure it out
I take it that would be blue power antenna wire out of the unit? I capped it off since I didn't have an automatic antenna. Figured it was just a power lead to engage a motor. With that being said, I can't recall any other wires I didn't connect from the Subie either.
If you bought an aftermarket radio harness adapter (like the one in the topic i linked to above), it should have had a blue wire on it for the antenna amplifier power. That's what you would hook the power antenna wire from the AVIC to.
Thanks, ironically I just came in from outside doing the exact thing.. Now if I can only find out what they bluetooth sounds like crap through the speakers...TBC
