97 Mitsubishi Eclipse Reverse & VSS Wire Location?
By RRM707 · Apr 02, 2008in Vehicle Specific Wiring💬 4 posts👁️ 3,294 views
Posted Apr 02, 2008 · 20:49 UTC#1
If I'm not installing a camera, do I even need the reverse wire...? If so, where could I find it? Thanks!
Posted Apr 02, 2008 · 23:44 UTC#2
Speed Sense yellow/white data link connector
The data link connector is under the driver side dash.
no, if your not using a camera you do not need it
Posted Apr 16, 2008 · 14:59 UTC#3
vss: Position 14 of 16 Pin Data Link Connector, driver side of console, yellow/white
Posted Aug 15, 2013 · 03:10 UTC#4
Well, I'm planning on using the backup camera at some point, so knowing where I can patch in to reverse would be helpful.  I guess I could technically patch in to the reverse lights,...
