NAV Warning Every Time?
By CMA · Apr 03, 2008in General💬 8 posts👁️ 1,361 views
Posted Apr 03, 2008 · 04:34 UTC#1
Just installed AVIC D3 and everything went smooth. Sounds and works great.
The only strange thing is that every time I go to the NAV menu after starting up, there is a Warning Message that I have to select "OK" to accept the license agreement.
Is there a way to get rid of this, or is this possibly a problem with power continuity when ignition is off?
Posted Apr 03, 2008 · 04:36 UTC#2
No, most all nav systems have that. You're stuck with it
Posted Apr 03, 2008 · 05:26 UTC#3
Its true, I wanted to get rid of my warning at every start but theres no work around.I have an Eclipse unit.
Posted Apr 03, 2008 · 13:11 UTC#4
ok i was wondering the samething thanks
Posted Apr 03, 2008 · 22:28 UTC#5
It's hardwired into the unit as a safety precaution. There's no way around it.
Posted Apr 07, 2008 · 14:57 UTC#6
Back when I had my factory NAV, I just got used to tapping 'OK' when the car started. If you do it often enough you'll start doing it automatically without thinking about it.
Posted Apr 07, 2008 · 19:18 UTC#7
I have my N-3 set-up so it will turn on with my autostart, and wanted to kill the warning screen to. There has got to be some way to hack the software on an update cd or something doesn't there. it really annoys me.
Posted Apr 07, 2008 · 19:43 UTC#8
You're fighting a losing battle, man. Give it up.
