I decided I want to keep it simple and NOT get an external amp. Decided to try to make the most of the built in amplifier.
I've got a 2007 Ram Quad cab. Front doors are 6x9. Rear doors are 6.5
I Just received 4 speakers from crutchfield Boston sx95 for front and sx65 for rear.
Was reading the manual and instead of using the rear speakers, you can use the rear output for a sub and set up a HPF for the front speakers. Crutchfield has some compact bazooka tube subs that have low RMS rating.
This sounds like it would work well _in theory_ but wondering if this will work well. Anyone use the built in amp to power a small sub?
I figure with the 6x9s in front, the rear 6.5s are redundant and may only help with imaging.
