GEXP10HD HD Radio module - my impressions
By gkurt · Apr 03, 2008in General💬 24 posts👁️ 4,478 views
Posted Apr 03, 2008 · 14:48 UTC#1
I installed the GEXP10HD into the Z2 last night. Here's my initial impressions.
The audio quality, once it finds the HD sub channel on an analog channel, is excellent. While I do not have XM on the Z2, I have it in another car through the factory (Acura) navigation/stereo headunit, and I would say the HD radio audio quality is better than XM (again, since I do not have XM on the Z2 it is not exactly apples-to-apples).
The display sucks, absolutely sucks. I don't know what the XM module displays on the Z2, but on my other car it tells all. With the HD module, the best you get is 8 tiny charactors, scrolling in a small window. To describe this as disappointing is an understatement. To make matters worse, you need to choose what is displayed in the scrolling window, call sign, artist or title.
The presets do not have any label like in the FM/AM source. There are numbers you can touch, but no label. Why I cannot explain.
I don't know what the XM module displays on the Z2, but I'd hoped the HD module would display station, artist, title in readable letters, like it does on my other car. Using only 2% of the screen is just plain rediculous.
If you are looking for better audio quality, the HD module will provide this. But don't expect title and artist info, that feature is basically worthless.
Posted Apr 04, 2008 · 02:24 UTC#2
Hi,
Does the FM/AM still work in the FM/AM source or does the HD module take over for everything?
From the sound of things it take all three sources and puts them in control of the EXT source.
Posted Apr 16, 2008 · 13:41 UTC#3
I hooked up a GEXP10HD to my Z2 last night, and I can confirm that the original AM/FM still works fine, but you have to split the antenna lead so it connects to both the AVIC and the GEXP10HD. Try finding an automotive antenna splitter though. :) I didn't look online, but I had no luck finding one locally so I built my own with an antenna lead extender I bought at Auto Zone and the extender that came with the GEXP10HD.
Why would I want to have both the original AM/FM interface and the one that comes with the GEXP10HD? Because gkurt is right...the new one SUCKS! As bad or worse than the Sirius inteface. (I have both XM and Sirius connected.) I got HD basically so I could check it out and see what it's like. It would be a huge bonus if the GEXP10HD overrode the built in AM/FM interface...but instead it will appear as either EXT1 or EXT2, depending on what else you have connected.
I found it difficult to hear any huge quality difference on the FM side...analog FM sounds pretty damn good on the Z2 as it is. Mainly I think I'll probably use it to listen to the HD sub channels. HD AM sounds pretty good from what I've heard so far...about the same as XM or Sirius; I can definitely hear the compression artifacts. It does drop back to analog once in awhile when something starts interfering with the signal, like going under bridges or driving near powerlines, and the analog signal on the GEXP10HD sounds quite a bit worse than the Z2's built in AM receiver.
Is it worth getting? In it's current form I'd say most people wouldn't think it's worth the hassle...hopefully by the time the AVIC-Z5 or the AVIC-Z6 comes to be it will be built in. :)
Posted Apr 23, 2008 · 15:01 UTC#4
Does anyone know if this has been improved/fixed with Z3?
Posted Apr 29, 2008 · 00:13 UTC#5
ok, this module sucks for it interface. How do you know when you are getting HD channels? How do you get it to go to the second part ie. 106.3-2?
Posted Apr 29, 2008 · 02:20 UTC#6
No, its the same. Its fixed on the F-series
Posted Apr 29, 2008 · 19:38 UTC#7
When it pops into HD mode, it add "-HD" to the displayed station text. You can also hear when it transitions. To go the HD-2 station, wait for the main channel to pop into HD mode and push the right arrow ">" button on the screen. You can also save the HD-2 channels as presets.
Posted Apr 29, 2008 · 21:46 UTC#8
You should not have to 'split' the antenna the hd box is what controls all of your am/fm/hd the hd only kicks in when available
Nope, you don't have to....but if you don't the internal AM/FM interface of the Z is rendered useless...in favor of the HD box's interface which is available from one of the 'EXT' keys, and which sucks and blows at the same time. :)
I prefer to have both working so I can only go to the HD when I feel like it. What would be nice is if the box were to somehow replace the internal interface with something as useful or better...but it doesn't.
Posted May 25, 2008 · 05:42 UTC#9
When you split them up did you lose quality in reception? I am installing my hd tuner mainly cause my regular fm/am reception is crappy. I really don't know why its like that but hopefully by going hd it will fix my static problem.
Posted May 25, 2008 · 10:53 UTC#10
Probably an installation error. Pioneer has had the best am/fm tuner for decades
Posted May 26, 2008 · 02:04 UTC#11
I just installed one of these too.
There is also a list of 6 buttons called "function x", where x is 1 through 6.
If you hit the "function 1" button, it will toggle between three text displays. It will show the station, then press the "function 1", and it will display the artist. Press it again and it will display the song.
What is completely stupid is that only half of the screen is used for these buttons, and the other half of the screen is blank. There is plenty of room on the screen to display all three lines simultaneously. Instead, you have to hit a button, and you see a line scrolled with about 10 letters showing.
I can see the accident happening now. Someone gets into a car accident cuz they were trying to see the artist and song info and had to keep watching the screen because of the scrolling until they have seen the whole line before they hit the button again to see the song info.
Maybe a lawsuit will motivate Pioneer to change this when someone gets into an accident!
DON'T HIT THAT "FUNCTION 2" BUTTON! If you do, it will erase all of your presets and redo them with best station memory.
Posted May 26, 2008 · 02:16 UTC#12
The sound produced is very good when it works. HD Radio only transmits with 1/100th the power of the FM station. I can only receive HD radio stations in the "city grade" antenna pattern. This is only for very close stations.
There are 6 fm stations I listen to via FM, and I only get two of them in HD.
The reception isn't very good.
Posted May 26, 2008 · 05:38 UTC#13
That's why we need keep hounding pioneer to change how the hd looks on the z series.
Posted May 26, 2008 · 06:02 UTC#14
You can hardly complain for a piece of hardawre that was not designed to work for your decks.
Posted May 26, 2008 · 09:27 UTC#15
I tend to agree. Not because I think an $1800 deck should work better, but because Pioneer basically told you it wouldn't work!!!! EXTdevice=shitty. We all learned that with previous models. Unfortunately, you have to work with whats available until they fix it (which appears to be the F-series, but who knows until it shows up.)
Posted May 26, 2008 · 17:27 UTC#16
I guess the same goes for the CD/DVD changer.
I have it on EXT as well and the interface is just crap.
Posted May 26, 2008 · 19:29 UTC#17
I don't think buying a new model is a fix. Hopefully if a lot of people complain about it that pioneer would do something. We can only hope.
Posted Jul 10, 2008 · 20:02 UTC#18
so is it worth it? I mean I was going to buy it today actually but won't if its crap
Posted Jul 11, 2008 · 14:26 UTC#19
this is the reply I recieved from pioneer:
Thank you for contacting Pioneer Electronics, Inc.
The GEX-P10HD was manufacture after the AVIC-Z2, The hardware in the AVIC-Z2 does not have HD tuner control built in, therefore the Navigation sees the hd tuner as an external device, nevertheless the navigation can control it and it will display the artist and song information. At this time we do not have a unit with an internal HD tuner.
Thank You,
Pablo
Customer Service Representative
Posted Jul 11, 2008 · 16:23 UTC#20
Silly reply from the Pioneer CSR, it's 100% a software issue, not hardware.
The Z-series runs Windows CE and the only limitations to what it can/cannot support natively is due entirely due to software.
Posted Jul 11, 2008 · 16:34 UTC#21
i know. and let him know in my response
Posted Jul 11, 2008 · 16:36 UTC#22
I'm not liking this pablo guy:
Unfortunately that is how you can operate the HD tuner when connected to a unit that is not HD ready, as it's the case with the AVIC-Z2 and AVIC-Z3. As I mention before the hardware of the navigation units where not design with the HD control, so therefore a firmware will not be able to update the navigation unit.
Thank You,
Pablo
Posted Jul 11, 2008 · 16:47 UTC#23
Yeah, you probably won't get much in the way of answers from anyone in Pioneer Customer Support. They're trained on the product and how it operates, just enough to give generic help or tips. They don't know anything more technical than that. Probably the only way the Z-series will get any kind of major updates is if it comes down from the execs at corporate, and they couldn't care less about what you do with your existing AVIC as it's already bought and paid for. All they care about is selling the new models.
Sometimes hackers are able to improve an existing product if someone in the software engineering department leaks betas or software development tools. I don't see this happening though, I doubt anyone here knows anyone in the software engineering department at Pioneer, especially since most software development probably takes place at Pioneer HQ in Japan under a very strict NDA.
Posted Jul 11, 2008 · 19:09 UTC#24
I give up
My convo with pablo:
Inquiry Type:Feature and Specification
lstPublishers:0002
lstTitles:B00002-Car Products-Navigation
Inquiry:Hi There,
I'm currently a proud owner of an AVIC Z-2 and I broke my FM
antenna in a car wash and decided that instead of buying a new
motorized antenna assembly from Toyota to just go ahead and
upgrade to HD radio since it would cost around the same. However
while reading up on the Pioneer GEX-P10HD I discovered that it
doesn’t work well with my AVIC Z-2. I really like how the tuner
currently displays my stations and feel that not only would i be
making a visual downgrade, but having to control the stations
with an external tuner is annoying as well. Since the Z series
is your premier series I was wondering If you all plan on doing
any firmware updates that would fix this problem. I could buy a
whole new radio for the price of the Pioneer GEX-P10HD that has
HD radio already built in. Anyway before I make my final choice
on whether or not to buy the HD tuner I would just like to know
if there is an update in the mix. Thank You
Warner Wilson
On Fri Jul 11 10:01:35 EDT 2008,
Thank You,
Pablo
To: [email protected]
Subject: Re: RE:Feature and Specification|B00002|5613868963
[#1196263]
I understand that, but have you seen the display on the z-2? With
in a small window. To make matters worse, you need to choose what
I hoped the HD module would display station, artist, title in
the screen is just plain ridiculous.
Also I hear that the Z-3 is exactly the same. I understand that
the Z-2 doesn't have an internal tuner but is there no way to
release an update to make the display look a little better?
On Fri Jul 11 12:25:45 EDT 2008,
unit.
Thank You,
Pablo
C
Subject: Re: RE:Re: RE:Feature and Specification|B00002|5613868963[#1196263]
I don't really understand why the z2 would be limited by hardware.
Correct me if I’m wrong here, but doesn't the Z-series run
Windows CE? If so wouldn't the only issue here be software? I'm
sure there would be a bit of programming involved, but to say that
it would be impossible to write some code that would convert the
incoming information from the GEX-P10HD into something a little
more user friendly and aesthetically pleasing just leaves me
perplexed
In order to run the HD tuner the AVIC-Z2 must have the circuitry built into the unit, its not a matter of programing.
Thank You,
Pablo
