I have a 2006 Toyota Solara that had a factory JBL Nav unit.
Last November I had it replaced with the D3 as well as blutooth, XM, etc.
The installer indicated an adapter was needed since a wiring harness wasn't going to work.
I've now had 2 drained batteries since the install of the D3. I called Pioneer and they said the adapter could be the problem and they recommend using Soundgate adapters.
Can anyone help explain to me why this external adapter is needed, is there anyway around not needing one and could it be causing a drain on my battery?
Thank you
