Hi guys. I've searching until I was blue in the face, but still have questions. I am retarded with this stuff, so if you answer, imagine you are talking to a kid hahah
To let you know what I am trying to accomplish - I have a non-Bose 350Z, I want to install PAC SWIPS and no rear view camera.
1) on the PAC SWIPS - how do I connect the resistors to the white wire? Solder them all together?
1a) It says: Red wire: Connect the INTERFACE's red wire to a switched +12volt wire. This is usually a red wire on the aftermarket wire kit."
....can you explain this in Layman's terms? haha
2) The solid blue "Antenna Control" from the AVIC harness to the solid blue Nissan harness...should I just cut the little metal thing at the end of the Antenna Control and solder them together?
3) I still have a few wires left over after soldering most of them together. I have a solid black and orange w/ black stripe left on one pig tail. And on the other pig tail I have a black w/ white and a blue w/ white. Where do these go?
4) Still have a pink wire on the AVIC harness called "Car Speed Signal Input"...I've seen this discussed, but I keep getting turned around in circles. Does this hook up to the VSS?
5) Other than the Yellow w/ black Mute wire that I have gounded, do I need any of the other Audio inputs if I don't have an amp or anything like that?
Thanks again everyone. This site has been helpful with everything else. And yes, I should've just paid someone to install it for me ![]()
