I have followed the instructions in detail on how to edit phonebook entries on the d3, however the edit box never comes up after I press on the item to edit?
what the hell am I doing wrong?
I'm having the same issue as well. Since the D3 cannot sync my phonebook with my iPhone, I need to manually input the number. I'm able to input the first 6 phone numbers but that's all. For the 6 numbers that I was able to insert, I'm unable to type the First/Last Name for those numbers.
So the two issues I have so far:
1) Cannot access the phonebook so I'm unable to add more numbers
2) Unable to type the First/Last name for the first 6 numbers
Thanks in advance!
Thanks in advance!
You cant edit names if the phone book has not been uploaded, as is the case with iphones.
your sol.
you can only add those 6 presets and thats it.
the name only comes up when those presets are in the btb200 internal pbook that should have been uploaded.
yours didnt, so number only for you.
ctn28,
did you upload your phonebook?
if no...then same applies to you.
SOL
if you did upload phonebook, sorry dunno whats up.
