Z2 Volume stuck
By AMRguy · Apr 05, 2008in Hacks/Mods💬 5 posts👁️ 1,003 views
Posted Apr 05, 2008 · 20:03 UTC#1
I've been up and running with my new Z2 for a couple of weeks now. The last couple of days if I am navigating and trying to adjust av volume odd things happen. I now have no audio on XM or AM or FM . Volume is fine on navigation, DVD is LOUD even on 1 (maxed out on 1).... so is the music library. I can adjust up to 40 and it stays at the same level 1 to 40...0 goes quiet. XM is getting signal... I looked for mutes, adjustments that I may have hit... held various buttons in...checked the manual for help recalibrating volume...factory settings restore....and I guess its a soft reboot woth the tiny pinhole button on the front.....
Any ideas ? It's LOUD and basically unusable except for navigation.
Christopher
Posted Apr 05, 2008 · 20:41 UTC#2
are you using the internal or an external amp?
Posted Apr 05, 2008 · 23:10 UTC#3
Internal amp
Posted Apr 06, 2008 · 20:54 UTC#5
Thanks for the PDF Inferno Sir... I didn't know there were that many reset options. It started working on its own last night. Hope thast doesn't meant here might some "bad circuits" in this new deck
Thanks again for the info.
