I have read through the troubleshooting section on this forum and couldnt find an answer to my problem. The problem I have is that I cant use the route view or any other views except for the main map view. The gps doesnt help me find my directions at all since it doesnt direct me where to go. I had it working once but it disappeared after about 30 seconds. I had it professionally installed and bypassed. What can be the problem? I have a route established but still not getting anything. please help!!!!
Missing map views on Avic-D2
Just to clarify, you are looking for the different map views after a destination is selected on the d3? The reason i ask is because you cannot go to different views ulless you have a route selected. If you are doing this right, you probally need to check the bypass, sounds like the wire may have come loose from the harness.
so a detached cable can cause me to not use the guide and route view? The vehicle gauges view is clickable but theres a message that says its not usable across the screen.
Set a destination. Then try to use the other views
I tried that. Set destination and sometimes the other views shows up but then disappears. What could be the problem? Bypass wire not connecting??
No, the bypass has nothing to do with the views. If you have a route programmed in, and you don't get those views, its broken
even though it works sometimes? Is it possible that it could be because the dvd I'm using is not an original copy? Can that cause it to malfunction?
Go into your manual try it again!
Buy a real disk and try it out. Seems like an easy test
ok.. it started to work today. All I did was clear everything from the previous owner. I just had it installed 2 days ago and *knocking on wood* hopefully it'll keep working. Can something like old preferences keep it from working properly?
No
That's the copied disk not working correctly.Sometimes they copy 100%,sometimes not at all and all in between.I've been there many times.
