Help with power for Bt-200 and Sirius!
By capper · Apr 05, 2008in Problems/Troubleshooting💬 5 posts👁️ 715 views
Posted Apr 05, 2008 · 23:35 UTC#1
They both need power somehow. How did you wire them up, or where? The ground is already pretty used up with the bypass setup.
Posted Apr 06, 2008 · 01:58 UTC#2
Tap into the power and ground in the harness
Posted Apr 06, 2008 · 03:33 UTC#3
that would be about 6 wires tied together, is that good?
Posted Apr 06, 2008 · 07:22 UTC#4
You can use the same constant power wire going to the radio. And just ground the units anywhere there's a bolt/screw going into the metal of the car.
Posted Apr 06, 2008 · 14:13 UTC#5
i used my cig. light to power my bt 200.
