bad reception
By ctaranto · Apr 06, 2008in General💬 6 posts👁️ 1,151 views
Posted Apr 06, 2008 · 02:31 UTC#1
just had my d3 installed and my radio reception is not good... it's ok in some spots then very bad in others... this is with stations that usually get very good reception
thanks
Posted Apr 06, 2008 · 04:45 UTC#2
Did they hook up the antenna? And power antenna wire?
Posted Apr 06, 2008 · 15:22 UTC#3
year/make/model of the vehicle?
Posted Apr 06, 2008 · 21:46 UTC#4
Check your install settings
Posted Apr 08, 2008 · 00:44 UTC#5
I have a 06 Le with Bose system in Nissan Armada
Posted Apr 08, 2008 · 02:12 UTC#6
Could be the installer did no connect the power antenna lead, there may be a setting in the D3 not done right, or you may have a bad antenna adaptor. I would taqke it back and let them troubleshoot for you.
