automatic lower volume on navigation guidence
By azote · Aug 09, 2006in General💬 4 posts👁️ 961 views
Posted Aug 09, 2006 · 04:15 UTC#1
is it posible to make the AVIC-z1 to lower the volume automatic when is going to give a direction like it does when you are going to make a voice command or receive a bluetooth call ?
thanks
Posted Aug 09, 2006 · 11:14 UTC#2
It does do that. Not only does it do that, you have a choice of -10db, -20db or music off.
Posted Aug 13, 2006 · 04:06 UTC#3
right on ducatiboy, wenever receivin a nav direction or bluetooth call it'll mute it to w/e level u have it on. wen in av screen, hit av settings, then hit system settings, then at the bottom left-hand corner make sure the mute is on guide/vr/call n next to it u can change the mute level to -10db, -20db n mute all.
Posted Aug 15, 2006 · 00:21 UTC#4
Thanks man I forgot that those settings existed
