how do i bypass i grounded the green wire like i was told and when i drive it cuts out please help
Posted Apr 07, 2008 · 02:28 UTC#1
next time try the search, this has been beaten to death.
If you have the original cndv40 version 1.1 or 1.2 then just grounding the ebrake wire will perform the bypass. If you upgraded the unit with newer software then the only way to byass it is to open it up and solder to extremely small points together. If you don't want to do this then downgrade back to the original software.
the disc that i have 1.1 50 mt thats the 1 that came with it do i have to solder it still ???????
the original discs for the n1 were the 40's. the discs u have are for the n2, so i'm quite sure u'll need to solder as well
dammit i have the 40s to maybe ill downgrade
