Recorded music only plays back on left speakers
By smokenjet · Apr 07, 2008in Problems/Troubleshooting💬 21 posts👁️ 2,738 views
Posted Apr 07, 2008 · 12:42 UTC#1
When I play a CD is plays out of all 4, but when I record to the harddrive it only plays back on the left side. Pioneer was no help. Is this an internal problem or a software issue? I have tried 3 different CD's some original and some home made with no difference.
Posted Apr 07, 2008 · 15:25 UTC#2
I think CD and Library have their own A/V settings. I'd go into the AV system Setup for both and look for any differences.
EDIT:
Obviously whatever settings you have in either SHOULD work, but at least this will help figure out where to start.
Posted Apr 08, 2008 · 03:02 UTC#3
Have you tried a reset? This is a new one,I've never heard of this problem before. The reset is a wild guess to be honest. If it was a normal home recorder I would say you recorded in mono. It could be a read or record problem. Let me know what the fix is whenever you get it done.
Posted Apr 12, 2008 · 01:28 UTC#4
I just got my Z2 installed today and I have the same issue with the recorded music being played only out of the left speaker. The installer was like "wtf?" And could not fiure it out. I have not had any luck with any audio adjustments yet. I did notice that the nav voice is also only out of the let speaker. Can anyone help?
Posted Apr 12, 2008 · 02:19 UTC#5
Check this.
(Remember, most sources have their own settings, so it's possible that it may differ from how it's set on CD)
Source -> library -> AV Settings -> Staging -> position -> center
and
Source -> library -> AV Settings -> FAD/BAL ->
Posted Apr 12, 2008 · 03:39 UTC#6
I printed out your reply, went to my truck and tried it. Although it made sense, it did not work. Thanks for trying. Everything will play on all speakers except recorded cds - even during the record mode it only play's iout the left speaker - front and rear.
Posted Apr 12, 2008 · 03:56 UTC#7
Have you tried playing your recorded cd's on your home cd player just in case it may be your home recorder thats at fault?This theory won't work for smokenjet.
Posted Apr 12, 2008 · 08:36 UTC#8
Wow... I'm stumped.
Non fading output perhaps? I really don't know....
Posted Apr 12, 2008 · 12:19 UTC#9
I did not mean to imply that the cd's themselves are recored. They are orginal cd's and when played in the z2, they play just fine. But when you record them onto the HD, while its recording you only here the music out of the left speakers and it does the same on playback. I'm stumped too!
Posted Apr 12, 2008 · 21:18 UTC#10
THIS BLOWS I am sending mine back in. Nothing seems to work here. Burned CD, Originals. It plays fine but when recorded and then replayed it doesn't. I walked thru with Pioneer tech support to see what they knew and they had me remove the libary and reinstall after a reset and no joy.
In ya'lls opinion who is better California or Ohio tech support?
Posted Apr 12, 2008 · 23:21 UTC#11
Who ever solves this problem gets my vote! 8)
Posted Apr 13, 2008 · 06:59 UTC#12
your hard drive is set to MONO mode, return it to pioneer.
I completely made that up and have absolutely no idea what im talking about. Can i have your vote anyway?
Abe
Posted Apr 13, 2008 · 13:33 UTC#13
This problem has been reported by other users before. I recall reading several posts from last summer with the exact same issue. Do a search and look for some posts from last year. I think the fix involved replacing the HD, although, if your unit is under warranty return that sucker and get a new one.
EDIT: Found it, http://www.avic411.com/forum/viewtopic.php?t=9038
looks like a return for a new hard drive is in your future. I'd give the level 4 reset a try first.
Posted Apr 13, 2008 · 21:16 UTC#14
I definitely agree that a level 4 reset should be tried first.. Don't know exactly why it fixed my problems, but it did when all other options were tried - even those suggested by Pio Tech.. sux that you lose all your library - but its better than ripping your unit out and sending it in.
Posted Apr 14, 2008 · 03:45 UTC#15
Thanks peeps. No really - I appreciate the efforts here. Revlis - I actually thought the mono thing too. BTW love the sense of humor! The last thing I want to do is have to send it back, and you are right - it may come to that. But I will try the level four reset first. Ok. Now.... whats a level four reset and how do I do it? :oops:
Posted Apr 14, 2008 · 12:26 UTC#17
Thanks for the info Inferno!
Posted Apr 16, 2008 · 20:25 UTC#18
Sounds like a bad connection
Posted Apr 16, 2008 · 21:54 UTC#19
Can you elaborate - what type of bad connection? Installation or with in the unit?
Posted Apr 19, 2008 · 00:40 UTC#20
WELLLLLL Mine shipped out today for Ohio. Be ther Wednesday. Do I have any takers on when I will get it back in my hands..... delevery to the 23rd April...... My guess is May 5th. Anyone else
Posted Apr 19, 2008 · 02:17 UTC#21
I only wish you the best however when I spoke with Pioneer, they said that it would be about a five day turn around sooooo, I'm waiting to see what happens with yours :P
