GPS Antenna- Inside or out?
By sportsfan21 · Aug 09, 2006in Hacks/Mods💬 6 posts👁️ 2,281 views
Posted Aug 09, 2006 · 05:16 UTC#1
I'm installing my AVIC-D2 this weekend and I wanted to know whether you get better reception if it is mounted on the roof or on the dash?
Thanks.
Posted Aug 09, 2006 · 05:28 UTC#2
Depends on the car. some vehicles have a metalized film in the window that can cause problems with a nav system picking up the gps signal. Best bet is to do the antenna last and try it inside first. If it don't work inside then outside it goes.
Posted Aug 09, 2006 · 12:46 UTC#3
In the dash! But check the many recent threads on the subject (Search).
Posted Aug 10, 2006 · 16:37 UTC#4
How would I know if my car has the metalized film in the window? I have a 2000 Nissan Pathfinder LE.
Posted Aug 10, 2006 · 17:30 UTC#5
do you have one of those white ezpass things? if that works on the inside then the gps antenna will too. Otherwise only way to find out is how I said before and do the antenna last.
Posted Aug 11, 2006 · 12:32 UTC#6
Ok, thanks.
EZPass works in my car so I guess the antenna will too.
