D3 Audio Problem
By jaysemien19 · Apr 08, 2008in Problems/Troubleshooting💬 5 posts👁️ 925 views
Posted Apr 08, 2008 · 14:48 UTC#1
Recently Reinstalled Amp+Subs in Ford F150. The Problem is now, the sub woofers play, but i get no sounds from mids/highs. I plugged in factory radio, mids/highs work. Any help!!!!!!!!!!!!!!!!!
Posted Apr 08, 2008 · 15:00 UTC#2
What exactly did you install, do you have an amp on the mids/highs as well as the subs? Did you rewire/replace the mids and highs or use the factory wiring and speakers? What year and model is your truck? If its fairly new with a high end factory system you mave have to get an adapter to turn on the factory amplifier to power the speakers (if you didnt rewire/replace them).
Posted Apr 08, 2008 · 15:08 UTC#3
Go into the settings and switch the rear output from subwoofer to full.
Posted Apr 08, 2008 · 18:09 UTC#4
Just an amp on the subs. I replaced the door speakers a long time ago. The amp was hooked up to the radio already, i had it removed for ford to change the carpet. Now im getting the amp reisntalled. and this problem occurs.
I was told my output could be bad. This is on the radio itself.
Posted Apr 08, 2008 · 18:14 UTC#5
I switched it, that didn't help neither.
