Install in Ford Edge
By 2006gt · Apr 09, 2008in General💬 14 posts👁️ 1,825 views
Posted Apr 09, 2008 · 18:11 UTC#1
Great site!
Did multiple searches and didn't find anything....
Just bought a D3 with Ipod and BT adaptors. I was wondering if anyone had done an install write up or if one from another vehical would work.
Thanks in advance! :wink:
Posted Apr 09, 2008 · 21:11 UTC#2
Don't have an Edge or I'd help you out, Paul. :D
Posted Apr 10, 2008 · 01:07 UTC#3
No one? No or no?
Posted Apr 10, 2008 · 01:37 UTC#4
I believe that one of the forums foremost contributors "Misfit" has an Edge. Maybe he can lend you some info.
Posted Apr 10, 2008 · 21:44 UTC#5
Thanks. I sent him a PM.
Anyone else???
Posted Apr 12, 2008 · 03:29 UTC#6
Can anyone tell if a voltage regulator is needed if you don't have the factory subs? It's just the base unit that came with the edge. The step down from the Shaker 500 I guess.
I just don't want that "POP" on start up.
Posted Apr 12, 2008 · 21:57 UTC#7
if you dont have a factory sub, you wont get the pop
Posted Apr 14, 2008 · 16:28 UTC#8
Thanks MisFit. I got her in everything is working great with the exception of the steering wheel control. I looked and looked and had a few people check the wiring and all looks good except it won't program the controls. It's hooked up exactly as instructed by PAC....
Also, no idea where the VSS wire is on the Edge. Anyone have any idea???
Posted Apr 14, 2008 · 22:35 UTC#11
2006gt both of the interfaces are from PAC the one linked to ebay is for your aftermarket installation (RAP, VSS, Illumination, Aux input, etc.) the one you list is only a interface that allows you to retain your steering wheels controls if you replace your factory radio, so if you would need both if you wish to retain steering wheels controls
I have a 2006 ford fusion with a D3 and no vss but could not find any info as to whether the adapter bashed listed above would work (other than PAC stating it does), but i can tell you that i do have the PAC SWC interface and it works fairly well
Posted Apr 15, 2008 · 17:42 UTC#12
Thanks for the reply saltshaker. I don't think I need both... I can hook my VSS, Illumination and RAP up directly to the wiring harness. I have a email off to PAC to help answer these questions. i'll let you know how it goes. ;)
Posted Apr 15, 2008 · 17:46 UTC#13
cool keep me posted i am very interested in getting vss to work (although the D3 is pretty accurate w/o) as are a fair amount of my fellow fusion owners
Posted Apr 18, 2008 · 16:03 UTC#14
Here ya go. I got mine finished up last night. Read this post... Not sure if the fusion will be the same, but you never know. Good luck!
http://www.fordedgeforum.com/index.php? ... c=728&st=0
