Can I play a DVD in the rear while using navigation?
By burner · Apr 11, 2008in General💬 7 posts👁️ 1,045 views
Posted Apr 11, 2008 · 00:38 UTC#1
Hey All,
Considering the Avic D3 and can't find some info on a question I have. I really need the unit to be able to play a DVD to a rear flip down screen (for the kids) while I use the navigation option on the main screen. It is my understanding that you need the navigation disc in the drive in order to use it, rendering the DVD useless. Can you pop the navi disc in, load the maps and pop a DVD back in? Does the nav DVD need to be in at all times when using the nav function? Thanks in advance!
Posted Apr 11, 2008 · 01:24 UTC#2
No, the D3 does not do Dual Zone (like you are wanting). The rear video out only goes activewhen the DVD or Aux 1 or Aux 2 are active. If you want dual zone and want Pioneer, go with the Z2 or Z3 )if you can find one).
Posted Apr 11, 2008 · 06:25 UTC#3
Thats not correct. You can certainly put your nav disk in, program in the route, let the D3 store it for a minute, eject it, put a movie in and send it to a rear screen(s) The navi will still work and you can view it by pressing the map button...unless you go very far off the route you have set, and then you will have to put the nav disk back in
What you won't be able to do, is listen to a different source while the movie is in there. You and your passengers are stuck listening to barney or whatever the kids are watching. If you want to listen to something else, step up to the N or Z series
Posted Apr 11, 2008 · 11:15 UTC#4
When the movie is playing in the back, is the nav screen visible on the D3 or is the movie shown in the front too?
(Will my kids start yelling the minute I press "map" because all of a sudden barney is gone and they see a map on the rear screen instead ?)
Posted Apr 11, 2008 · 16:34 UTC#5
The movie will always be shown on the back screen. The D3 doesn't send the nav screen to the rear at all
So, you will press map and have the map on the front screen so the police don't pull you over AND the movie will remain on the rears the whole time
Posted Apr 11, 2008 · 17:04 UTC#6
Thank god... my heart stopped after reading the first reply. I could already see myself returning the unit back.
Posted Apr 12, 2008 · 00:22 UTC#7
Thanks for the correction. Nev er knew that trick. Guess that was my one thing for the day.
