Trying to load a custom picture on my brother's AVIC-Z1. I have read numerous posts online, and spoke to the Pioneer tech guys 4 times. Nothing seems to work.
The problem is that when you go to the display menu, the "import from disc" bar does not let you choose it.
I have tried burning discs a zillion ways. I have tried the following methods...
-making a "pictures" folder, and tried it lower case, capitol, and lower case with a capitol P. I also tried labeling the folder "BG" as I found on an old Pioneer help FAQ on their site.
-adding an EXTRA 100mb of unreadable data. I am using word, pdf and zip files to take up the space. I have tired putting this data IN the pictures folder, and tried putting it just on the disc seperate of the pictures folder.
-tried burning the disk with XP, and also on a 98 machine with an actual burner program.
-tried just putting a bunch of pictures only with no filler data, in and out of the pictures folder.
-using .jpeg only pictures, and less than the maximum size.
The parking brake wire is bypassed on this unit, you can do anything at any time you are driving. No parking brake error messages.
I noticed that when I put in a disk with the pictures folder, it recognizes the CD-ROM and says CD-ROM INSTALLED. When you don't use the pictures folder, it says UNREADABLE DISC.
I have read something about not using "compressed jpegs". I don't know what that is, maybe someone could help there?
I am pretty sure I have done everything right. It seems to ID the disc, but maybe doesn't recognize the pics? I am just not sure what else to do.
Any help would be appreciated!
