So I just installed my D3 in my car this weekend. Everything works flawlessly but the speedometer and odometer stopped working.
I need help!! Is it a possibility that when I tapped the speed wire with a wire tap that it just cut the connect? Or did I blow something? A Fuse? The speedometer?
I tried searching the forums for similar problems but havent found someone who messed up like I did ![]()
This was my first automobile radio install in my life. I was pretty stoked about everything working flawlessly until I took the car for a drive yesterday.
Help will be greatly appreciated. I got a lot of cuts and bruises from this install so I would like to know exactly how I messed up so I can go for the fix and do it right the first time around to save myself from more cuts and bruises.
Thank You!
