Help Cant get Sub to Seal
By Blustang05 · Apr 15, 2008in Off-Topic💬 6 posts👁️ 1,504 views
Posted Apr 15, 2008 · 02:06 UTC#1
Hello I have Installed a set of CDT 8" Sub in to the doors of my 2005 Mustang. but the Passenger side will not seal. what Product could i use to Seal the mounting Flange. I Dont really want to use silicon because that my be a mess or a pain to remove if ever need be
thanks
Posted Apr 15, 2008 · 02:33 UTC#2
Ummmmmm, what?!?
Posted Apr 15, 2008 · 02:49 UTC#3
Dynamat or similar...
Posted Apr 15, 2008 · 02:57 UTC#4
Dynamat would probably work fine....or build a baffle from 1/8" Masonite and seal that to the door, mounting your woofer to the baffle...
Posted Apr 15, 2008 · 04:55 UTC#5
thanks for the tip on using dynamat
It did the trick !!!
Posted Apr 15, 2008 · 05:16 UTC#6
Groovy. 8)
