08 F150 FX4 Supercrew
By BlitzK · Apr 15, 2008in Vehicle Specific Wiring💬 6 posts👁️ 1,873 views
Posted Apr 15, 2008 · 03:06 UTC#1
I have a D1 (yeah... old) that I installed in my current vehicle.
08 F-150 FX4 SuperCrew will be here soon. Either going to go with a D3 or Z3...
Does anyone have the wiring diagram/info for the 08's?
Do I need to buy any type of dash kit?
The F-150 has the audiofile system installed... anything special I need to do to get that working?
Posted Apr 16, 2008 · 14:36 UTC#2
You do need some stuff to put the radio in that car.
Mounting kit: Metra 95-5812 or 99-5807
Radio Harness:
With standard audio system: Metra 70-5520
With amplified audio system: Metra 70-5521
Antenna Adapter: Metra 40-CR10
The book says it need an antenna adapter but I'm not completely sure if it does. I would say buy that from a local ccity and this way if you don't need it you can return it. If you want to integrate steering wheel controls order the piece from ebay pac swi-ps.
Posted Apr 16, 2008 · 14:40 UTC#3
it will need the antenna adapter and also the VSS is in the wire harness its grey /black. and steering wheel control is also there if needed.
Posted Apr 18, 2008 · 14:05 UTC#4
Radio Harness:
Thanks... actually, I have the 95-5812, 70-5521, 40-cr10, and pac swi-ps on order!
I think that should do it for the basic install items needed.
Posted Apr 18, 2008 · 14:09 UTC#5
I've seen elsewhere that the grey/black wire is no longer on the radio harness in the newer truck. Can you confirm this?
Also, where can I get the pin-out for the audiophile system so I can solder everything up on the bench?
Posted Apr 18, 2008 · 15:43 UTC#6
that would be correct the 08 f150 no longer has a vss wire in the radio harness. A 5521 will give you all of the wiring you need from the audiocrackhead system in those trucks.
