Master Reset of D1
By mikemjohnson · Apr 15, 2008in Problems/Troubleshooting💬 6 posts👁️ 917 views
Posted Apr 15, 2008 · 22:26 UTC#1
I'd like to reset the D1 back to how it was when it came from the factory - there are a lot of problems with the used D1 i just bought, for example, in Nav, i cant set a new destination, only 'return home' and i cant even change settings when i click the settings tab under the navigation main menu. so i hoping this will fix it.
how do i master reset the entire d1
p.s. i searched
EDIT or tell me how to make it so i can do an address search - right now its greyed out and i cant do anyhting but 'return home'
Posted Apr 15, 2008 · 23:48 UTC#2
Put your parking brake on
Posted Apr 16, 2008 · 06:52 UTC#3
it was since i have a 5speed and i was parked on a hill but its been bypassed
Posted Apr 16, 2008 · 07:35 UTC#4
im guessing they're bypassed it wrong, because in some submenu i found, it said 'parking brake: OFF'
so my next question is how do i bypass it so the parking brake is always 'On?'
Posted Apr 16, 2008 · 07:42 UTC#5
There is one open hole in the main power harness. Take a wire/pin you are not using or find one from another harness and stick it in that open hole. Ground the other end of that wire and the parking brake wire
Posted Apr 16, 2008 · 09:06 UTC#6
k thanks a lot bud, i guess ill use the A.ANT since im not using it (thats for cars that have retracting antennas correct?) do i just pull it out and plug it in the new slot or do i have to strip the wire or anything of that nature?
