Please help my NAV is Lost
By andru1313 · Apr 16, 2008in Problems/Troubleshooting💬 7 posts👁️ 949 views
Posted Apr 16, 2008 · 13:23 UTC#1
Ok I get in the car the other day plug in my where I want to go and away i went. I notice that the arrow is pointing to the side and it is moving sideways. I think WTF so I change views same thing. When I do the driving view it won't even show the road I am on. It has me in the correct vacinity but not on the right roads. I go in to check the dashboard display and the speedo says function not available. I am baffeled. Everything else works but the Nav. It can't find me.
For me to get to the GPS antenna i have to remove my cluster which I don't want to do cause it is very difficult. Does anyone else have any other suggestions as to where I can look? I am going to remove the headunit and look to see if anything is unhooked but i doubt it's that. PLEASE HELP...
It is a Pioneer Z1 i have had it for almost 2 years and it has worked flawless.
Posted Apr 16, 2008 · 13:38 UTC#2
Try resetting the callibration data, and if that doesn't help, try a total reset.
Posted Apr 16, 2008 · 13:48 UTC#3
how do you do a calibration reset? Is it where you reset the learning data? a
Posted Apr 16, 2008 · 18:19 UTC#4
go to:
-Navigation
-settings
-hardware
-3D calibration settings
-touch learning status
-reset all
(see also pages 98, 99 Z2 manual )
Posted Apr 16, 2008 · 18:40 UTC#5
Ok kewl. Thanks... I hope this solves the issue....
Posted Apr 22, 2008 · 17:06 UTC#6
UPDATE...
That solved the issue. Thanks again
Posted Apr 23, 2008 · 07:36 UTC#7
UPDATE...
Great. Glad to help :wink:
