D3 Sound Settings
By peste19 · Apr 17, 2008in General💬 5 posts👁️ 1,322 views
Posted Apr 17, 2008 · 12:14 UTC#1
I installed my d3 yesterday and i noticed that the sound quality is cheap.... has no bass tweeters are popping if i put it a little bit louder and i was wondering what settings you made to make the sound better
Posted Apr 18, 2008 · 02:19 UTC#2
Use the EQ presets or custom your own.
Posted Apr 18, 2008 · 06:02 UTC#3
First thing to do it turn off the soundstage enhancement thing. That messes with the levels a lot. Then experiment with different EQ settings, loudness, fade and balance.
Posted Apr 23, 2008 · 00:18 UTC#4
Adjusting the EQ can really anhance the sound....sub settings...highs lows mids, etc
Posted Apr 24, 2008 · 01:49 UTC#5
Just curious, but what kind of car is this in? Amps? (factory or aftermarket) Wiring harness adapter used with install? Almost sounds like a phase problem to me. A little more info than "sounds cheap" might help you get a more accurate diagnosis/solution :D
