Playing Music CD's... CD comes out hot.. D3 unit
By johnboy3779 · Apr 19, 2008in Problems/Troubleshooting💬 8 posts👁️ 1,107 views
Posted Apr 19, 2008 · 03:21 UTC#1
I recently installed some rear moniters and a AV-1 input onto my D3. Now when i try to play a music CD, the music jumps, I sometimes get a disk read error Code-02, and when i pop out the CD the center of the CD is very hot to the touch. Now if I play a DVD I have no problems.
Anyone have any clues as to what might be going on?
Posted Apr 19, 2008 · 14:52 UTC#2
i have no clue wish i could tell u maybe the cd is bad is it just that cd or all ur cd's?
Posted Apr 19, 2008 · 16:51 UTC#3
It is all CD's. Another thing I noticed today is it seems that the unit takes a little longer to turn off even after I turn the car off.
Posted Apr 19, 2008 · 18:49 UTC#4
year make model of the vehicle? Any oyther after market equipemnt installed?
Posted Apr 20, 2008 · 02:47 UTC#5
06 Scion xB. Nothing else audio/video installed.
I tested it again today. DVD's and the DVD for the GPS I have zero problems. Radio and the AV-1, again no problems. Music CD's (original or my own copies) both still skip and after a while I get the message at the bottom "error code-02"
Only other thing i can think of that might cause anything is I added an add-a-line fuse at the ACC fuse block. I used it cause I needed a 15 amp line and to make it easy and to make sure i didn't put the wrong fuse in the wrong slot i used that one.
Posted Apr 20, 2008 · 04:56 UTC#6
No, the 15 amp fuse wouldn't cause that problem.
Posted Apr 21, 2008 · 05:01 UTC#7
OK I guess a better question might be this... What could cause the CD's to become so dang hot and what does Error Code-02 mean?
Posted Apr 21, 2008 · 05:34 UTC#8
I don't know why it gets so hot but Error code 2 is the CD is either scratched,dirty or the disc is loaded upside down.
