Hello-
I've been to the wiring section, and I used the link to determine where the VSS wire should be connected to for my 2004 Toyota Tacoma Double Cab truck. I also found a thread on another message board that had some images on the wire.
According to the wiring section, I am supposed to be looking for a green wire with an orange stripe. I've double checked, and I can't seem to find that specific wire. Here is what I'm looking at.
In the wiring section, there should be a 28 pin connector with a green wire with an orange stripe on it. Here is a picture from a 2001 Toyota Tacoma 4x4 Double Cab. The green/orange wire looks like it is in the bottom row, third from the left.
Here is a picture of what I think is the same connector, but the wiring looks different. This is from a 2004 Toyota Tacoma 4x4 Double Cab. The wire that is in the same location is green, but has a yellow strip on it.
Tomorrow I plan on trying to put a meter on the wire, and see if the reading changes when I drive.
Any help would be appreciated. Thanks.
