AVIC D2 stalling
By ORRYOWL · Apr 19, 2008in Hacks/Mods💬 9 posts👁️ 1,587 views
Posted Apr 19, 2008 · 19:49 UTC#1
Thanks to everyone with the help on getting it all wired up, antenna came in yesterday and DVD's in today. Now, what i've noticed is that after the upgrade, the system seems terribly slow, I cant input any destinations or do anything, pressing Dest. on the unit is unresponsive and it is horribly slow. Is this the DVD's problem? They were brand new.
Posted Apr 19, 2008 · 22:00 UTC#2
Edit* Got it working, unplugged battery/replugged.
Now it's an issue of grayed out options...I thought it was because the parking wire wasnt grounded, did that and still grayed out
Posted Apr 19, 2008 · 22:56 UTC#3
It sounds like your by-pass isn't properly connected.
Posted Apr 19, 2008 · 23:01 UTC#4
Yeah I just regrounded it into the ground for the unit. I think the problem is bigger now....the unit is taking FOREVER to load the dvd's even after they seemed to be working. Im guessing it's because they are copies and the guy I bought them from copied something wrong.
Posted Apr 20, 2008 · 05:04 UTC#5
What DVD's are you referring to? Nav. or movies
Posted Apr 20, 2008 · 05:55 UTC#6
I was referring to the Navi DVD's. But after fiddling with it from 2pm till 7 I gave up, even had to jump start the batter a few times. It's not the DVD's fault. Its the bypass, and after grounding that damn parking wire so many times my navi options are still grayed out. Even after the whole sticking wire into the empty pin
Posted Apr 20, 2008 · 06:28 UTC#7
Go back and read up on the bypass.I have the Eclipse unit and it is THE easies to bypass.Just ground the brake wire and that's it.Do a search for bypass,I'm sure its something you're leaving out.
Posted Apr 20, 2008 · 06:42 UTC#8
Read this and double check your wires.I copied this from whtcrxghst
entry.
Ground your parking brake wire. There is any empty slot in the harness for the deck that you must ground, sp use one of the wires you are not using and put in that empty hole and run that wire to ground. Done
Posted Apr 20, 2008 · 07:43 UTC#9
Thanks man, I'm gonna retry in the morning. It could be because of how I was grounding it, not sure. If that doesn't work then oh well, I'll do it the Cop-friendly way. Funny thing is that, after grounding them, I dont get the screen on check the wires or anything. Seems to work as it lets me use AV...just the gray options
