problem
By openendstraight · Apr 20, 2008in Problems/Troubleshooting💬 4 posts👁️ 841 views
Posted Apr 20, 2008 · 00:30 UTC#1
I have encountered a new problem with my Z-2 (upgraded to Z-3). If I turn the car on to fast, meaning not stopping at ACC position for a few seconds, it does not power on. If I turn the car off and back on, it powers on.
Before anyone asks I had this same problem before doing the upgrade, it actually is less noticeable now, but still happens.
Does anyone have any idea why?
Posted Apr 20, 2008 · 02:00 UTC#2
What kind of car do you have?
EDIT: nevermind, read your signature.
The unit needs X amount of power to power up. Sounds like you're not getting enough in the "ON" position...which is strange. You should have the same amount in ACC as in ON (b/c it should be the same line providing power). I'm not a GM guy so I'm not familiar with the nuances of GMs.
Posted Apr 20, 2008 · 11:42 UTC#3
Sounds like your Class 2 adaptor is not recieving the correct turn on signal. The GM factory radios are more forgiving for this error (I see it from time to time). Try this for a few days a see if it fixes anything- turn your key to the "on" position and wait 2-3 seconds, like you were letting the fuel pump prime, then start it. You should notice it turns on every time. If not, have your Class 2 module checked out.
Posted Apr 23, 2008 · 21:06 UTC#4
I turn it to on and wait a few seconds and the unit turns on. Then I turn on the car, and the lights on the unit go off for a couple of seconds, and then come back on.
If I turn the car on too fast, sometimes it doesn't come on at all. Then when I turn the car off it comes on. Then I turn the car back on and it flicks off then on again.
I would think this is an adaptor problem, right?
It is not a connection problem, because the radion never cuts out when I am driving.
Any other ideas.
