d1 bypass...iv searched to
By hockeymutt · Apr 20, 2008in Hacks/Mods💬 2 posts👁️ 1,694 views
Posted Apr 20, 2008 · 03:26 UTC#1
hey hows it goin i just installed my d1 and in the instructions it says hook it up to the power side of the e brake. so i figured i would just solder it to the acc and that didnt work... but i've read that it needs to be grounded?
any help is apperciated.
Posted Apr 25, 2008 · 01:30 UTC#2
take out your telemute wire... and insert it in the other open socket on your wire harness... ground both the wire you just inserted and the p brake wire and boom your done...
if done correctly you should not get a warning when you first turn on the unit.
Your unit thinks it is being bench tested...
I just did this to mine. sometimes the wire will not sit correctly and you must redo... it took me 3 times because the wire would pop out when installed on the unit.
