Thanks guys...
I guess I'll just be installing a switch on the acc wire or amp turn-on wire.
That sucks the D3 doesnt actually turn off when you want it OFF
The whole reason is because of a slight noise that is driving me nuts.....does anyone else find the D3 to be a noisy head unit? I
I ask because Ive rewired my Jeep three different times now changing things around, the first time I was picking up bad feedback through the RCA's from an airbag computer in the console. The second time I was changing to different amps and location so I rewired the Jeep.
Yet I still have a noise that Ive had since day one and I just cant get rid of it.
Its not a ground loop/alternator noise, its just a static feed back of some sort, like a quite hiss when the volume is down low or when the radio is suppose to be off, thats how and when I realized the amp was still on.
So my next test is to unplug the RCA's from the amp with the engine running and the D3 on or off and see if the noise goes away, if not, maybe its the amp.
I just figured its not the amp because Ive had the same noise now with two different configurations and also different amps.
Being that Ive been installing for so long, maybe Im just too picky, but it sucks that I only have these kind of problems on my own vehicles and almost never on the customers
