Finding the Bypass switch, help!
By ummjay · Aug 11, 2006in Problems/Troubleshooting💬 10 posts👁️ 2,340 views
Posted Aug 11, 2006 · 00:29 UTC#1
Hey guys,
Im getting my n3 installed tomorrow. I just opened it up to find the sticker and I can't find it. It looks like it is under a piece of metal that has the headunit attached to it. How do you remove it to get under it to get to the sticker for the switch? Someone please help so I can get this before I bring it in! thanks!.
Posted Aug 11, 2006 · 00:36 UTC#2
take off the trim ring around the radio and remove the sleeve. on the bottom there is a piece of silver void tape. that voids all warranty.
Posted Aug 11, 2006 · 01:22 UTC#3
Posted: Fri Aug 11, 2006 12:36 am Post subject:
You may not want to void the warranty before you have it installed. If the unit is defective and you have voided the warranty, you'll be SOL.
Posted Aug 11, 2006 · 11:42 UTC#4
i just wanted to look. im trying to get around it without voiding the warranty. how do you take off that sleeve and remove the trim?
Posted Aug 11, 2006 · 12:45 UTC#5
2 things
1 just looking at the switch VOIDS WARRANTY. you have to remove the void sticker.
and second (not to be rude) but if you cant figure out how to remove the plastic trim ring and the sleeve then i wouldnt mess with the piece.
Posted Aug 11, 2006 · 12:50 UTC#6
im just afraid to mess with it because i don't want to mess it up.
Posted Aug 11, 2006 · 14:12 UTC#7
how do you remove it to get to where the sticker is. im going to try a few things to get to the switch without voiding the warranty. ill keep you posted once i figure out how to get that sleeve off.
Posted Aug 11, 2006 · 15:54 UTC#8
unclip the trim ring. It may be tight but it dose come off. then look at the front of the radio. You'll see 2 small screws on each side of the face. those screws are what hold the cage onto the chassis of the n3. Grab a #1 phillips and remove all 4 screws. the cage will then slide off. Turn the chassis upside down and look at the white sticker. Right by where it says pioneer is the cover for the bypass switch.
Posted Aug 14, 2006 · 11:49 UTC#9
i found it thanks.
Posted Aug 14, 2006 · 11:50 UTC#10
i found it thanks.
