radio reception and CD text etc
By fylor · Apr 22, 2008in Problems/Troubleshooting💬 13 posts👁️ 1,413 views
Posted Apr 22, 2008 · 15:31 UTC#1
Hi there
I live in Spain and am a newbie here.:D
Have just fitted D3 and really like everything about it. Have 6 disc changer and i-pod and all are great. EXCEPT radio reception ie ordinary stereo FM. My car has a rear window aerial and booster but the quality of radio is a lot worse than the OEM unit. Can I tune the set to the aerial to improve reception? Have tried reset but does not improve. Have tried local setting etc etc.
Also on CD changer or head unit can you put in disc title or CD text or is it a 'read only' feature?
any input appreciated
Posted Apr 22, 2008 · 15:38 UTC#2
I'm not sure about the CD text, but did you hook up the power antenna wire to the antenna booster? If your antenna is boosted the reception will be crap unless it is powered up.
Posted Apr 22, 2008 · 15:53 UTC#3
see the other thread you posted about this....i gave you an answer.
Posted Apr 22, 2008 · 16:14 UTC#4
Wow, Deja Vue.
Posted Apr 22, 2008 · 16:29 UTC#5
There's no E in Deja Vu... :P
Posted Apr 22, 2008 · 16:44 UTC#6
Vu- pronounced "VOO"
Vue- pronounced "View"
Posted Apr 22, 2008 · 18:28 UTC#7
Well, now I know why I got an E in English on my report card. :P
Posted Apr 22, 2008 · 18:34 UTC#8
It's not an English word... lol. >_>
Posted Apr 22, 2008 · 18:46 UTC#9
Just teasing you but its a French phrase.
This is going to become a "Haze the new guy" thread pretty soon...hahahah
Posted Apr 23, 2008 · 08:49 UTC#10
thanks for all the feedback and the french/english lesson.
Possibly the most relevant point is the power feed to the antenna. (and the info on the other thread about CD text) My car is a subaru forester. I guess I need to check the wiring diagram for the connector block and see if there is a feed for the antenna amp. The Subaru block is a single 17 pin block which I got an adapter for to suit the standard ISO connections.
Posted Apr 23, 2008 · 16:08 UTC#11
Well that don't make no sense. I eat french fries all the time... ;) Ok, I'll stop now.
OP: Hope it's just the simple matter of that power up antenna wire. Good Luck.
Posted May 02, 2008 · 11:42 UTC#12
Just a note re antenna amplifier. Had a chance yesterday to pull everything out again and attach power to amplifier and everything is great! Many thanks esp HiFiSi :D
Posted May 02, 2008 · 17:54 UTC#13
8)
