Nebiw, with a Q - Suddenly, positioning is all worng
By UKCamaroSS · Apr 23, 2008in Problems/Troubleshooting💬 2 posts👁️ 836 views
Posted Apr 23, 2008 · 15:09 UTC#1
Hi from a Newbie!
I have an Avic X1 (Euro model similiar to N1 I believe), which has been fitted in my 2000 Camaro SS (I imported the car from Canada), for several years, but now, it has no idea where I am.
When I go to the status menu, it shows no satellites being received, but says the position is OK. The VSS is hooked up and the hideaway unit is facing the correct way.
Does anyone have any idea's as to what would cause me to loose all satellites?
Also, as there are virtually no Camaro's over here, the shop that installed the unit made a bit of a hash of the job - so can I just check where you would suggest the hideaway unit and GPS antenna should be positioned, in a Camaro?
Currently, the brain is mounted upside down, to the underneath of the passenger seat - the unit is actually mounted to MDF wood, which is positioned over the seat rail.... and I have no idea where the GPS antenna was placed!!
Thanks for any help,
UKCamaroSS
Posted Apr 23, 2008 · 18:27 UTC#2
Have them move the GPS antenna onto something metal, preferably on the dash or the roof
