i was disappointed that the avic cannot survive "cranking"
i came from a carPC, which can be running while the motor is off, and when the motor is cranked, it wont restart the PC, it can take like a 5 second crank.
no go on the avic though, the entire thing reboots if im listening while "on" and then start the motor
this is normal right?
Abe
edit: the reason this matters so much is because it resets the bluetooth connection and it can take like 1-2 minutes to reconnect (unless you do it manually)
