Chevy colorado vss???(noob)
By d1_drifter · Apr 25, 2008in Welcome/Site News💬 3 posts👁️ 4,416 views
Posted Apr 25, 2008 · 05:22 UTC#1
Whats up peeps, i need some help on locating the vss wire for a 2004 chevy colorado. anybody have any ideas? i have been reading some forums, but just can exactly find it. Anybody have any pics?
thanks,
rob
Posted Apr 25, 2008 · 08:00 UTC#2
This is the best I could do.I just copied everything.Sorry no picks.
CHEVROLET COLORADO 2004 4DR TRUCK
Security Color Polarity Location
Battery WHITE/BLACK (+) IGNITION SWITCH HARNESS
Ignition 1 WHITE/GREEN (+) IGNITION SWITCH HARNESS
Starter 1 (+) IGNITION SWITCH HARNESS
Domelight Super WHITE (-) AT THE BODY CONTROL MODULE PIN # A46
LF Latch GRAY/BLACK (-) AT THE BODY CONTROL MODULE PIN # A32
- Note YOU MUST DOUBLE DIODE ISOLATE EACH WIRE TO PREVENT FALSING
RF Latch GREEN/BLACK (-) AT THE BODY CONTROL MODULE PIN # A38
LR Latch BLUE/BLACK (-) AT THE BODY CONTROL MODULE PIN # A44
RR Latch BLACK/WHITE (-) AT THE BODY CONTROL MODULE PIN # A39
Parking Lights BROWN (+) AT THE HEADLIGHT SWITCH OR PIN #A48 IN A GRAY
CONNECTOR AT THE BODY CONTROL MODULE
Low Crr Pk Lights BROWN/WHITE AT THE HEADLIGHT SWITCH OR PIN #A7 IN A GRAY
Remote Start
Accessory 1 WHITE/RED (+) IGNITION SWITCH HARNESS
Tachometer (AC) UNCOMMON WIRE AT THE COIL PACK OR AT ANY FUEL
INJECTOR
Low Crr. Pk Lights BROWN/WHITE AT THE HEADLIGHT SWITCH OR PIN #A7 IN A GRAY
Brake Lights LIGHT BLUE (+) AT THE BRAKE PEDAL SWITCH
Reverse Lights LIGHT GREEN (+) AT THE FUSE BOX UNDER THE HOOD
Horn GREEN (-) AT THE STEERING COLUMN HARNESS OR AT THE BODY
CONTROL MODULE PIN # A25 IN A GRAY CONNECTOR
Doorlocks/Windows
Power Unlock DARK BLUE (-) IN THE DRIVERS KICK PANEL OR PIN A12 IN A BLACK PLUG AT
- Note TO UNLOCK JUST THE DRIVERS DOOR ONLY, PULSE THE WHITE WIRE AT THE BCM, PIN # A12
PowerLock LIGHT BLUE (-) IN THE DRIVERS KICK PANEL OR PIN A11 IN A BLACK PLUG AT
Driver Mtr Unlock TAN (REV) AT THE LOCK SWITCH IN THE DRIVERS DOOR
Driver Mtr Lock GRAY (REV) AT THE LOCK SWITCH IN THE DRIVERS DOOR
Pas Mtr Unlock TAN (REV) AT THE LOCK SWITCH IN THE DRIVERS DOOR
Convenience
All Hazrd Lights WHITE (-) AT THE HAZZARD SWITCH OR AT THE BODY CONTROL MODULE
PIN # A48
Parking Brake LIGHT BLUE (-) AT THE PARKING BRAKE SWITCH
Modules
Module 1 BCM - BODY CONTROL MODULE IS LOCATED IN THE PASSENGERS KCIK PANEL
Posted Apr 28, 2008 · 01:17 UTC#3
I have a z2 installed in my colorado and I used the speed sensor wire. I will try to get some pics when I get to work on monday. It is located on the passenger side frame rail right across from the exhaust manifold. On the other forum im on they say its the tan wire on that speed sensor plug. all i did was tap into that and i havent had any problems, hope this helps.
