sirdrac15 said:
It's a 2003 X type> I believe I have the factory head unit in. It's a V6 2.5L AWD. Here's an example of the head unit:
http://cgi.ebay.com/ebaymotors/Jaguar-X ... dZViewItem
I hope this helps you.
I have a Jaguar 2002 X-Type and recently put the Z1 unit in it.
I ordered the install kit and wiring harness from Nexxia, an UK online auto audio website. Look at
http://www.nexxia.co.uk/Car_Stereo_fitting_kits/jaguar.htm.
However, you must be aware of a few things...
- The X-type will not fit a double din radio like the Z1 flush. It will need to stick out at least 1 inch from the current dash. This is due to the climate control distribution boxbeing behind the top part of the area.
- This requires a professional install to be done since they will have to craft your kit. However, having the one from Nexxia will cut costs since they can sculpt the neccessary adjustments on to that as a base.
- You will need to take out the spacer from your drive shaft so that it sits lower and the screen can clear the knob when you open the Z1 to put in or take out a CD/DVD and in park.
- Once installed, it sits low in comparison to where most people have it installed. You will need to take your eyes completely off the road to fiddle with it while driving.
Custom radio install creation cost me $200 from Tweeter, but that price might be lower than normal. it is usually around $300-$400 for a custom install. As I said, the install kit from Nexxia does remove a good amount of the work stability-wise. That does not include installing the other components.
However, I am completely happy with my setup. I have the Bluetooth adapter, XM radio with NavTraffic and the remote adapter so that I can still use the Jaguar steering wheel control. If you want Bluetooth or NavTraffic, then you are forced to go with the Z1, which is not so bad a choice at all with its stylings, features and 30GB HDD so that no Nav disc is necessary.
If you do not need nor plan to use Bluetooth or NavTraffic, then you might want to go with the single din Pioneer unit that automatically pulls out and up for the display when your car is active. It will not get you any higher a screen position though, since it will need to be installed on the bottom half of the install kit. Additionally, the install kit is grey, not the black in the US X-Type, so you will need to paint it to match your interior.
Anyways, good luck.
Ceger
