Hey guys,
I had my D3 professionally installed a few months ago and just today decided to pull open the dash to do the bypass. Unfortunately the company that did the work apparently used completely different connectors to do the job. The car is a 2005 Pontiac GTO and requires a VW harness to do the job. I believe these are the harnesses they used:
http://www.installer.com/item/display_i ... it=71-1784
http://www.installer.com/item/display_i ... it=70-1784
It appears that they cut apart the Pioneer harness and spliced the wires with the pioneer harness wires on one end and plugged the wires usually in the white connector into the opposing sides connector. So I can locate my mute wire (yellow and black) but it is in a different location all together. I took a bunch of pictures to try and illustrate the dilemma. Does anyone have any ideas how I can make the wiring work?
