Greetings,
I'm new here. I hope someone out there can help me out...
I have the AVIC D3 with a separate Mono Amp for the sub and a 4 channel amp for the front and rear speakers. The whole setup was working fine and then suddenly about 2 weeks ago, my front and rear speakers went out, but the sub continued working. If I use the off button on the AVIC panel and turn back on, still no sound. Now, if I turn the car off and then turn back on, things go back to normal.
Now, yesterday, the same thing. I got into my car, turned on the car, started the A/C, wasn't driving for more than 30 seconds and the front and rear speakers go out. Again, the only way to restore the sound is to turn the car completely off. Even after I did that, 30 seconds don't go by and then it happens again. Gave up and re-started the car later... all was fine. A few extra data points:
1. This problem is not consistent. That is, it does not happen all the time.
2. When it has happened, the head unit was not in use very long (e.g. less than 10 minutes), so I strongly doubt this is an overheating issue.
3. The mono and 4 way amps have a light on them. Supposedly, if a short were to take place after the amps, the amp light would turn red. When the problem last occured, I checked the amp lights and they were at a healthy blue (e.g. no problems).
The only thing I can think of is there is a short and the head unit is turning itself off at the front and rear speakers??
Any thoughts here would be appreciated. Thanks, Matt
