Avic N4 Bypass- White Harness Not Used?
By MikeD · Apr 26, 2008in Hacks/Mods💬 4 posts👁️ 2,899 views
Posted Apr 26, 2008 · 19:36 UTC#1
Guys,
I recently tried to modify my Avic N4 for Video Bypass. I went through all the Stickies i could read.
From what I can see, the N4 does not use the white harness that the D3 has . The D3 posts all show a wire terminating in the "Bypass" hole on the white harness. (mute wire-><->ground wire<->parking brake--)
my N4 only has the blue harness. The blue harness has no open holes.
I removed the yellow/black mute wire, but where should it terminate?
I have attached some pictures. Any guidance would be appreciated
Posted Apr 26, 2008 · 20:56 UTC#2
You need to use the white harness. It came with it
Posted Apr 27, 2008 · 23:56 UTC#3
I found the White harness with all leads. I'll give it a another try, Thanks for the Help
Posted Mar 13, 2009 · 21:14 UTC#4
How did it go? Mine only uses the blue harness and eveywhere i look they talk about the white harness. Pictures would be nice. THanks
