Z2 reboots with error after firmware update
By Anemathis · Apr 28, 2008in Problems/Troubleshooting💬 5 posts👁️ 1,050 views
Posted Apr 28, 2008 · 16:31 UTC#1
I installed the freeze/lock fix just last night and now my z2 will just continually reboot over and over. It says, "Starting pioneer navigation system" for about 1 to 2 seconds and then, "Starting Update", then "Update Failed"
It just keeps doing this untill I turn the car off, over and over...
Any help or suggestions are much appreciated!
Posted Apr 28, 2008 · 16:33 UTC#2
This question comes up every week or so it seems.
In short, It's the disc. You have a few options:
  • [*:90l7bxbg]leave it in and keep letting it reboot. It may be able to get the file it's crashing on[*:90l7bxbg]take out the disc, let it boot, put it back in, etc.[*:90l7bxbg]Burn it again, slower, on different media and try again
Posted Apr 28, 2008 · 16:35 UTC#3
Thanks Inferno, I will try different media at slower burn =)
Posted Apr 28, 2008 · 16:39 UTC#4
Another question...
Can I use a DVD-R for the update media? I seem to have run dry on CD-R's
Posted Apr 28, 2008 · 16:52 UTC#5
Another question...
Step 3
Copy the "AVICZ1_HD1" folder and "Basefile.dat"on your CD-R.
*Note: Ensure these objects are located on the top layer of the CD-R.
Make sure that your CD-R follows these specifications as follows;
- You can only use a CD-R finalized with single-session format.
- You can only use a CD-R finalized with "Mode-1" format.
