Video using Aux Video In Wavy and Hard to See
By guruerror · Apr 28, 2008in Problems/Troubleshooting💬 4 posts👁️ 793 views
Posted Apr 28, 2008 · 21:03 UTC#1
Hello.
I'm preparing to install an XBOX in my H2 with an AVIC-Z2.
I did an initial test connection yesterday using the XBOX's composite video cable to the Aux Video In on the back of the AVIC. The picture is VERY dark and VERY wavy at times.
Has anyone experienced similar issues using the Aux Video In on this unit...and if so, do you have suggestions on how to get the signal displaying properly.
NOTE: After connecting the XBOX to the AVIC and seeing the poor picture quality, I disconnected it and hooked the XBOX up to flat panel TV in my shop (using the exact same cables)...the image was clear on the flat panel. So that rules out any cable length/signal quality issues.
I haven't been able to test another video source yet...I don't have anything else in my house with composite out...that's my next troubleshooting step.
Any advise or direction would be greatly appreciated.
Posted Apr 28, 2008 · 21:12 UTC#2
There are brightness settings on the Z2 (hit "V") you might want to check, as well as whether or not the illumination lead was toggled on or off. Other than that, I've not had any problems doing exactly what you're doing.
Posted Apr 28, 2008 · 21:20 UTC#3
I've checked both items you mentioned...they did not help.
The only two items that I can think may be causing the issue:
1. The connector (or a pin in the connector) on the back of the AVIC is loose. Maybe the ground for the Video In got pulled during the cable run. Once I find an alternate composite source to test I should be able to determine this.
2. It's some kind of 'ground issue'...how did you power your XBOX? I modded a carpc power supply so I could go DC to DC and jumped power and ground off of an accessory plug in the rear cargo area.
Posted Apr 28, 2008 · 23:16 UTC#4
First, I'd try to rule out faulty Z2 hardware with another video source. Camera with Video out would be easiest. If that fails too, well, there ya go.
If it's clear, then you might want to check power. I'm using a 250watt inverter. The xBox draws 74watts so pretty much anything should be able to drive it.
