Could my BTB-200 be damaged?
By JSG517 · Apr 30, 2008in Problems/Troubleshooting💬 3 posts👁️ 874 views
Posted Apr 30, 2008 · 03:04 UTC#1
This is confusing so stay with me ;-)
I have connected the D3 to Sirius SIR-PNR2 to BTB-200 and both remain grayed out on D3 unit. I am sure it is connected properly; I even tried switching around the cables and units to no avail. I checked fuses and grounds, no problems. If I connect the SIR-PNR2 alone it works sound and all, now if I connect the BTB-200 alone I get nothing it is grayed out. Once I PROPERLY connect the BTB and SIR together everything is grayed out. BUT! Here is the tricky part if I improperly connect the SIR and BTB they light up as if they work but no sound from either.
WON’T WORK:
(SIR) black/out ==TO== blue/in (BTB) black/out ==TO==blue/in (HU)
Or
(BTB) black/out ==TO== blue/in (SIR) black/out ==TO==blue/in (HU)
___________________________________________________________
LIGHTS UP W/ NO SOUND:
(BTB) black/OUT ==TO== blue/OUT (SIR) black/IN==TO==blue/IN (HU)
NOTICE HOW IT’S (OUT to OUT and IN to IN)
I have been trying for weeks now to wire and rewire the units together, am I missing a part that would allow the BTB & SIR to work together or could my BTB be bad. Any possible fix???
Posted Apr 30, 2008 · 21:21 UTC#2
The first combinations should work. Either one of the IP-Bus cables is bad or the BTB-200 is bad. The BTB-200 has constant power?
Posted May 01, 2008 · 02:10 UTC#3
Yeah constant power from 12v yellow wire in dash. If the ip-bus cables were bad would it allow Sirius to work?
