08 F150 VSS
By jrb03 · Apr 30, 2008in Vehicle Specific Wiring💬 11 posts👁️ 2,464 views
Posted Apr 30, 2008 · 03:26 UTC#1
Im about to install a D3 in my 08 F150 FX4 SuperCrew. I am looking for the VSS wire location. I have assumed it was in the radio harness, but have read that they took it out in the 08 model. If it is not in the radio harness like the older models, where is it?
Also, will I need an adapter for the radio antenna? Thanks for any info.
Posted Apr 30, 2008 · 04:59 UTC#2
Speed Sense GRAY/Black(-)AT PCM MODULE ON PASSENGER SIDE OF FIREWALL NEAR BATTERY PIN #63
Posted Apr 30, 2008 · 13:01 UTC#3
antenna adaptor is a 40-cr10
Posted Apr 30, 2008 · 18:11 UTC#4
Thanks for the info guys, antenna adapter is on the way. So I guess its true, there is no VSS wire in the radio harness or in the cab somewhere? That stinks.
Posted May 01, 2008 · 05:04 UTC#5
Correct. You can also grab it at the wiper motor, less wiring, but more to dissasemble. Do a search, somebody posted a picture here.
Posted May 07, 2008 · 12:25 UTC#6
and if you find that thread, post the link here.
Posted May 07, 2008 · 16:06 UTC#7
I never found it. It could have something to do with the search on this site sucking hard. I will be doing the install in the next couple of days and will post my findings.
Posted May 08, 2008 · 13:46 UTC#8
OK, Update after two D3 installs on 08 F150. The antenna adapter mentioned above is correct. The VSS wire info is not. Both my FX4 Supercrew with Audiophile, and my brothers STX Supercab with regular CD player had the VSS wire in the radio harness. The wire is Gray with Black stripe. Hope this helps someone in the future.
Posted May 08, 2008 · 22:28 UTC#9
Sometimes the info thats printed is wrong or hasn't been updated.Even my vss wire wasn't in the spot that was indicated.
Posted May 09, 2008 · 03:56 UTC#10
Im sure your info is correct, I found it in the radio harness so I didnt need to go fishing for the pcm. Some say the VSS wire is no longer in the radio harness in the 08 F150, I just wanted to let people know I found it in two 08's so make sure and look before digging for the pcm.
Posted May 24, 2008 · 23:16 UTC#11
Speed Sense YELLOW/BLUE (AC) AT ABS CONTROL MODULE ON DRIVER SIDE FIREWALL
