Need some help resetting the clock on a D3. I've looked in the manual and can't find how to do this.
clock setting
The clock minutes will set automaticly using your GPS
The hours can be set using the timezone feature, in gps mode
Raiden
if your avic isn't bypassed then you'll have to set the parking brake to adjust the time.
Still having a problem with setting the clock. I quess the navigation needs to be reset?
so yeah just bought a d3, live in nova scotia canada, atlantic time and i cant get it to the right hours, puzzeled tried everything, can anyone help
so does anyone know how to change the time zone
It also took me a while to figure this out when I first got my D3.
The time zones are changed by using a +hour value in the nav settings area (can't remember the exact location off hand, sorry).
The default unit time zone iirc is the set for west coast. So, you'll have to add "4 hours". That is, +4 in the clock/nav settings. -> the time displayed on the unit "should" be the same as it is in Vancouver before you change the settings.
Also don't forget daylight savings, you'll have to add an extra hour. I'm hoping you'll be able to advance the clock by 5 hours. But my fear is that it won't let you set it to further east than atlantic time. My fingers are crossed that it's not restricted to only +4 hours.
good luck.
-> I'm in Toronto
i know how to set the time, but this up 3 down 3, plus the summer time is bullshit, how can such a great unit have such a stupid clock, im in altantic canada and my unit show 1 hour behind..
