Problem with my BT phone
By ccameselle · May 01, 2008in Hacks/Mods💬 13 posts👁️ 2,797 views
Posted May 01, 2008 · 19:45 UTC#1
Hello guys,
I am new to the whole AVIC D3x thing. I am trying to set up my Cingular 8125 phone with my BT unit and it is not working. Is there a hack out there to make it work?
Thank you
Carlos
Posted May 01, 2008 · 20:56 UTC#2
Is that windows based?
Posted May 01, 2008 · 20:57 UTC#3
Yes it runs WM 5
Posted May 01, 2008 · 22:45 UTC#4
Your gonna need the Jetware program to make it work, www.jetwaremobile.com
Posted May 01, 2008 · 23:11 UTC#5
What he said...
Posted May 02, 2008 · 12:34 UTC#6
Can I use the 30 day version or do I need the complete version? Is there anyone out there that is willing to share the complete version?
Thank you
Posted May 02, 2008 · 12:44 UTC#7
You can use the free version for 30 days to see if you like it, make sure it works with your phone etc.... However, for the registered version you have to provide your phones serial number and that registered copy is valid only for that phone, so it cannot be shared. Beside its only 15 bucks. I feel its worth it just to be able to transfer the whole phone book over at one time instead of one by one. Just my 2 cents.
Posted May 02, 2008 · 15:25 UTC#8
My copy of Jetware is registered and it never asked me for my serial number on my phone????? :?:
Posted May 02, 2008 · 19:13 UTC#9
Well I said serial number, I meant phone ID number, I think it may also be called the ESN number, you need that to register your copy of Jetware...
See here....
http://www.jetwaremobile.com/bthfx/purchase_Step2.html
Posted May 04, 2008 · 01:34 UTC#10
Ok I got the trial jetware software an the phone connects and it works. The phone connects and I can make calls. Now the problem that I am having is that is not showing the caller info and it is not allowing me to use the phone book. If I get the full version will that problem go away or that is something that I will not be able to fix with my HTC 8125.
Thank you
Carlos
Posted May 04, 2008 · 06:18 UTC#11
Register the phone
Posted May 04, 2008 · 23:34 UTC#12
The phone is already registered. any other I deas?
Thank you
CC
Posted Jun 07, 2008 · 23:06 UTC#13
Not sure about the phonebook problem your having, but I have no caller ID either.
You do have to go into the blutooth options (hands free utility, jetware) under Programs, in there are options for what features jetware will handle. you have to check caller ID as I dont think its turned on by default.
Dont expect everything to work perfect, cause it doesnt. voice command...forget about it...caller id (at least for me) forget about it.
Crazy fast power drain on a treo 750 with BT enabled? you bettcha
Worth it? For sure
