Did I foob the bypass? Error message on screen.
By typhoon43 · May 01, 2008in Hacks/Mods💬 4 posts👁️ 1,027 views
Posted May 01, 2008 · 21:30 UTC#1
This deck was previously bypassed (Z2), so I assumed I only needed to ground the parking brake and then the #1 pin of the AV2 pinout. I didn't get the AV2 harness when I bought it so I used a very small Centronics pin with what can only be described as like 22 gauge wire (VERY THIN) and then crimped a 16 gauge lead with a ring terminal and grounded it to the deck chassis.
When I start the truck, I get a message that my "parking brake has been incorrectly wired" or something to that effect. I KNOW the Parking lead is grounded well, as it shares a ring with my gauge grounds. I guess I'm asking if that warning is normal if the 2nd wire isn't grounded properly. I don't want to pull the deck out again to find out it's something else.
Thanks guys!
Posted May 01, 2008 · 22:43 UTC#2
That message will pop up when the second wire is not properly grounded. Sounds like you know where the problem is.
Posted May 01, 2008 · 22:59 UTC#3
Thanks for the heads up Hyper. To the garage I go! Have to get ready for the Z3 image tomorrow!
Posted May 02, 2008 · 12:47 UTC#4
See Big Floppies recent post. Everyone needs to offer feedback on their experience with the upgraded avic Z1/Z2. We may have a problem to solve.
