External guidance speaker
By executioner · Aug 12, 2006in General💬 8 posts👁️ 1,733 views
Posted Aug 12, 2006 · 23:14 UTC#1
Will the G.SP Guidance speaker output on the back of the n2 work by itself? The manual says to be used with a multi channel processor but I dont have that. I have trouble hearing the voice through my speakers. I thought if I could plug a small speaker into this and mount it in the head liner right above my head it would help.
Posted Aug 16, 2006 · 13:21 UTC#2
Try turning up the volume on the guide voice. It's in the nav menu under settings, hardware volume, voice volume. I've never had a problem getting enough volume out of that, even to the point of being obnoxious.
Posted Aug 16, 2006 · 21:33 UTC#3
It is turned all the way up. I can hear it but it gets no where near obnoxious. The ol ladys onstar in the Monte carlo will damn near scare you out of the car. I would just prefer it to be louder, to me it is marginal.
Posted Aug 17, 2006 · 15:06 UTC#4
Do you have it set to mute the music during voice nav. ?
Posted Aug 17, 2006 · 15:46 UTC#5
yep
Posted Aug 17, 2006 · 16:07 UTC#6
Are you sitting in the front seat ? Just kidding. Like Jimmy I have my nav volume on a low setting and can hear it fine. I do ride with my windows up and have a muffler on my car.You would think that if your units music is loud then the nav voice should be too.Can't answer the aux speaker question . Good luck. Oh just remembered the speaker options for nav voice. LEFT/RIGHT or BOTH. Did you check that? I use both speakers , (L+R) on the GUIDE VOICE button.
Posted Aug 18, 2006 · 14:41 UTC#7
Are you using amplifiers in your system or running the avic directly to speakers? Also, what kind of car?
Posted Aug 18, 2006 · 16:52 UTC#8
1992 Chevrolet Pick Up, The main speakers are run directly from the avic and there are 2 subs that run off of separate amps. Basically I am wanting to know if there is a powered signal coming from the plug on the back of the n2 or does this need a powered speaker.
