confused about ipod cable/adapter
By ro.sniper · May 05, 2008in General💬 5 posts👁️ 1,073 views
Posted May 05, 2008 · 18:57 UTC#1
I'm a bit confused about the ipod cables available for the z series, I saw a couple on ebay, they use the ipbus connector at one end and the ipod connector at the other, but i don't see a box like pioneer's website. Will this box less cable work? Will i be able to see the titles?
Posted May 05, 2008 · 19:28 UTC#2
At best, you're looking at a glorified AUX adaptor that feeds teh line out from the iPod's doc to the Aux on the Z2 via IP-Bus. The adaptor would have to be the last item on the IP-Bus chain, and would replace a CD changer. Control would be 100% through the iPod, and the head-unit would have to be in AUX mode. All you'll see on screen is the Head Unit's AV background and the word AUX. No charging would occur (unless it also ties in with the car's 12v system -- I've seen a few that do).
At worst, it's not really an IP-Bus connector and is instead the CD-I200 direct control cable made for special head units that support it. the plug is shaped like a square with one of the corners heavily rounded off, almost to the point that it looks like a diamond. This is not IP-Bus.
Posted May 05, 2008 · 20:34 UTC#3
so i need the 30 dollar plus adapter?
Posted May 05, 2008 · 21:29 UTC#4
If you want to be able to control the iPod through the Z, you'll need the CD-IB100II. No exceptions.
Posted May 06, 2008 · 14:48 UTC#5
Thank you, much appreciated
